230/100%'s and turbo pairings
94.5stroker
Phillipsburg Kansas
I have a 94 zf5 running 160/0% with a D66. I haven't been happy with the combo since I put it on. It is smokey and laggy even with different tunes. I recently found out that I have a leak in my uppipes and intake plenums, so I've decided it's time to change it up. I've decided to go up to 230/100% and try to shoot for the 500-600 range. It's my daily driver and I use it for towing around the farm some, usually not too heavy, but I want EGT's to be in check. I also want to keep the setup as reliable as can be (understanding that when you mod you increase the risk) will I be pushing my luck on a stock bottom end? I've been told that if I get a 1.0 a/r housing for the D66, an intercooler set up with new uppies and intake plenums to eliminate leaks, it will be a great combo. That it would do much better lighting the turbo with my manual, and keep the EGT's in check. After spending a lot of time comparing prices between getting all the pieces to keep my D66 running and just moving up to a T4 with either a S366 or S468 the prices aren't very different.
So my questions are which way should I go? I can sell the D66 and bellowed uppies, my stock turbo, 160 injectors, and a TS chip I had before my hydra to recoup some of the cost in switching to a T4. I just rebuild the D66 under 5k miles ago with a 360 kit and Beans new 66mm billet compressor wheel.
Are there any issues I will run into with the D66 and the 230/100's? Drive ratio, turbo life? Will the D66 with the tighter exhaust housing have issues on the top end?
If I should go up to T4 which is the better option the S366 or S468? Same question on drive/boost ratio and turbo life for those two.
I've spent a lot of time trying to get the thing smoke free and drivable and I am just tired of high EGT's and smoke. I also want more power, strange I know haha. Thanks in advance, hopefully you can decipher that mess.
ghohouston
Lewisville,Texas
But if you do get those injectors, your stock bottom should be fine, but stranger things have happened. It's always a crap shoot with performance parts. And I don't think you're going to be ear your hp goal with 230/100's... I'd say 500 if you're lucky with live tuning and everything else on the engine healthy as a horse.
94.5stroker
Phillipsburg Kansas
I'd fix the underlying problems before buying performance parts. Reseal the plenums and re seal/replace your up pipes.
Yeah think the uppies are the prob so getting new ones either way and I think the stock intakes are a joke so I wanna get rid of them too. So either way those two things will be addressed. Just wondering who as experience either way what would work better.
bruce
Middle east
Would I be better off to move up to 250/200's?
I've read where a guy made like 575 on PIS 230/100's and a 38r. Granted that was on dyno proven's dyno so take it for what it's worth. 250/200's and a 468 is nice combo but there have been plenty spit the rods out with that combo. You could get some 250/200's (same money as 230/100's) and detune them and run with the 366. With either though you're gonna need stud and valve springs
ghohouston
Lewisville,Texas
That's damn impressive for those injectors, imo. unless Tim just overbuilds and under rates his injectors.
Personally, I ran 238/100's and a 38r, and it was fun. Bone stock motor, no studs, valve springs, or rods, and never had a problem. Never dynoed it though
bruce
Middle east
Also I think you HBJ is better suited for the 100% nozzles. With either injector though there is a possibility you could chuck a rod, but if you drive reasonably you'll be fine.
gnxtc2
Bergen County, NJ USA
One of the best things I did to my truck....got rid of the "66" style turbo and went T4 with a BASB which is based of a BW S300 frame. Read my thread on "66" style turbos.
I have more than enough power to tow 23k (see build up in sig).
Billy T.
[email protected]
MossBack
UTAH
Billy T.
[email protected]
^^^this is dead on. Buy the turbo to fit the needs of the truck. I feel that if I can make 396hp with 160/80's and stock turbo and no i/c then 230/100's and custom turbo and IC should fuel well over 500.
Remember tossing parts on top of problems only make them worse
