25% discount on ford parts to members
sunrisefordparts
I will get it later this evening when I'm around the truck. Would you happen to know what the different weight reasons are?
the obvious would be between it being a diesel or a v10, others would be like the snow plow option or chassis cab vs having a truck bed.
Greger96obs
1996 7.3 oil cooler o-rings and gaskets
96' 7.3 need to reseal oil cooler
Ic3z6c610ba inner o-ring need 2
lIc3z6k649ba outer o-ring need 2
f7tz6a636aaa front adapter gasket
f4tz6a636a rear adapter gasket
Thanks,Greg
sunrisefordparts
Thanks,Greg
Ic3z6c610ba list $5.31 each sell $4.41 each
lIc3z6k649ba list $12.66 each sell $9.88 each
f7tz6a636aaa list $29.40 sell $22.93
f4tz6a636a list $18.62 sell $14.52
free shipping
q#371067
duddy
sloshkosh wi
8EA47463
Tie rod ends both sides, plus drag link joint at rh knuckle.
Also a quote for the lines to convert to post 5/21/07 build date for tranny cooler. This vin is what I would like to get to, 8ED41298. I am converting it from 8EA47463. I believe all I need is the two hard lines for the 41298 vin to make it work. Trying to eliminate that $200 filter under the bellhousing.
sunrisefordparts
8EA47463
lh tie rod list $211.95 sell $152.60
rh tie rod list $183.20 sell $131.90
right drag link list $131.28 sell $94.52
trans line list $86.33 sell $62.16
the trans lines coming out of the radiator wont ne to be changed just the main 2 lines to eliminate the filter assy.
q#371292
duddy
sloshkosh wi
q#371292
Is the trans line 1 qty for the two pices as an assembly?
