25% discount on ford parts to members
sunrisefordparts
I need a quote on the following parts for a 2005 Ford F-250 XLT 6.0 4x4
18mm headgaskets and dowel pins (one gasket per side)
MAP sensor
Intake gaskets
Thermostat housing
Thanks!
head gaskets list $197.94 each sell $154.39 each
map sensor list $93.95 sell $62.00
intake gaskets list $15.09 each sell $11.77 each
tstat list $28.83 sell $24.22
free shipping
q#380873
sunrisefordparts
2011 f350 VIN 1ft8w3bt1bec67454
need a price on a sync "APIM" (Accesory Protocol Interface Module) module i know these are vin specific and i need it to be programmed before it is shipped to me as well
well the module would run you $300 w/exchange (core $300) but as for the programming that is done when the unit is in the vehicle.
Matt_P
Lima, OH
Looks like Im gonna end up needing 12 more lifters for the 06 6.0 as well as prices on:
Rear cover gasket
Front main seal
Rear main seal
Upper and lower oil pan gasket
Camshaft
2 dummy plugs
sunrisefordparts
Rear cover gasket
Front main seal
Rear main seal
Camshaft
2 dummy plugs
lifters w/guides list $74.14 each sell $56.05 each (kit of 4)
Rear cover gasket list $17.97 sell $14.02
Front main seal list $24.40 sell $17.57
Rear main seal list $58.40 sell $42.05
Upper oil pna gasket list $14.54 sell $11.34
lower oil pan gasket list $13.06 sell $10.19
Camshaft list $1135.67 sell $858.56
2 dummy plugs list $21.76 each sell $13.06 each
$15 shipping
q#381074
jcain
BC3Z9D280A (i think this is the correct part number)
passenger side fuel rail for 2012 6.7
Matt_P
Lima, OH
$15 shipping
q#381074
I need to go ahead and order everything but the camshaft please
sunrisefordparts
I've tried calling a few times and someone mumbles something and puts me on hold. Tried 5 times different days different times. Is there a number someone can answer and help me?
Sam
i was off on vacation when you sent the vin # over and had a few guys filling in, what is it your looking for i can help you out.
sunrisefordparts
I want to replace my factory non nav sync head unit. So the whole thing I guess?
Sent from my Nexus 5 using Tapatalk
if the wiring works between radios then the unit is $733, if you have sat radio then you will have the antenna and wiring there and need to get a harness at $163 which would be the splitter for the nav and sat. if you dont have sat radio then you would need the antenna and harness which would run you $103.
