25% discount on ford parts to members
sunrisefordparts
8ra47463
2 rear seals.
8 rod bearings
1 main bearing set
16 injectors feed line kits
Gaskets for putting together one 6.4
Putting two engines together. I will call and talk to you after you get a initial quote.
heres the quote, should be all we need to seal at least one motor.
  • Q448462.pdf
SunStroke
Arizona
2000 F250 4x4 crew cab
two - V- Code front springs ( 2c3z-5310-ha )
two - Front leaf front bolts
two - Front leaf front nuts
two - Front leaf rear bolts
two - Front leaf rear nuts
two - Front leaf shackle mount bolts and nuts
sunrisefordparts
heres your quote
  • Q448933.pdf
Jarrod B
Corpus Christi Texas
internal filter list $44.64 sell $24.11
external filter list $45.91 sell $24.79
seal list $6.28 sell $4.14
trans pan gasket list $46.37 sell $33.38
fluid list $5.56 each sell $4.80 each
q#436199
Can I reorder this quote or I need a new one?
Also is there a gasket between the transfer case and transmission tail housing?
2006 f250 fx4 5r110.
Thanks.
sunrisefordparts
Thanks.
the pricing is the same so that's good, there is a paper gasket between extension housing and t-case. that gasket runs $5.31 and the new quote number is #450060
Dmstrucks02
Pearland, TX
Can I get a price on a driver's side valve cover for a 99 7.3L F6TZ-6582-BB I believe is the part
sunrisefordparts
Are you affiliated with the North Hollywood location? I found it a little cheaper online with that location
same owners different stores. if your closer there they would be able to order it up for you as well.
