25% discount on ford parts to members
Denver
America
Vehicle is a 2002 F250 4X4 PSD
Need prices for:
Front and rear U bolts and nuts. Rear has helper leafs.
Front brake lines from the frame to the caliper.
The clips/brake line mount that hold the brake lines to the frame.
Front ABS sensors
Front Rotors
Front pads
sunrisefordparts
Need prices for:
Front ABS sensors
Front Rotors
Front pads
can I get the last 8 digits of your VIN
thanks,
Sean
Denver
America
Vehicle is a 2001 F250 VIN 3FTNW21F7MA67132
Need prices for:
Rear blocks
2002 F350 VIN 1FTSX31F22EA82960
Front Rotors
Front pads
sunrisefordparts
Airbag HC3Z-25043B13-AA
Clock Spring HC3Z-14A664-A
Shipped to 76088
Hi,
the airbag lists for $169.38, your cost would be $121.96 , however due to it being hazardous material the shipping is $55
the clock spring lists for $62.72, your cost would be $45.16.. shipping is $9
thanks,
Sean
Q562057
Denver
America
Need prices for:
Front Rotors
Front pads
sunrisefordparts
Need prices for:
Front Rotors
Front pads
Front -U bolts: List $40.38ea -- sell $29.08 each
-nuts: List $3.50 ea -- sell $2.10 each
rear -U bolts: List $13.50ea -- sell $8.10 each
-nuts: List $2.50ea -- sell $1.50 each
Front brake lines: List $48.16 -- sell $31.79 each
Front Rotors: List $141.04 -- sell $93.08 each
Front pads: List $55.53 -- sell $36.65
thanks,
Sean
Quote-562233
duck
6.0L 4.5L HPOP High Pressure Seal Installation Kit 4C3Z-9B246-F
6.0L Front Cover and Low Pressure Oil Pump Kit 5C3Z-6608-B
Injector Pressure Regulator (IPR) Valve # 5C3Z9C968CA – CM5126
Rear Engine Cover Gasket & Seal Kit PN - 3C3Z-6G091-A
sunrisefordparts
4C3Z-9B246-F List $65.03 -- sell $46.82
5C3Z-6608-B List $647.62 -- sell $489.60
5C3Z9C968CA List $303.62 -- sell $200.39
3C3Z-6G091-A List $417.97 -- sell $315.98
+ shipping
thanks,
Sean
Quote#562372
unsung
I need upper front door weatherstrips (where the window rolls into), I can't find the part number. 2006 F350. The previous owner had the window deflectors and the glue won't come off.
Also need a drivers side headlamp harness / female plug for the H13 lamp. The retaining clip broke off.
sunrisefordparts
weatherstrips list for $175.00 each, your cost would be $126.00 each
the headlamp pigtail has a list price of $24.38, your price is $16.09
+ shipping
quote# 562522
thanks,
Sean
unsung
I searched on those before (six months ago) and they were nowhere near that cost, did prices go up?
sunrisefordparts
the discount we give hasn't changed, it is possible that Ford Motor Co. raised our cost. I can double check to make sure I have the right part numbers with your vin?
thanks,
Sean
CyrusLoewen
Glenn CA
What is you price on part #HC3Z9E464A ?
Also, what is the price on the 2 C shaped bars in the grille on a 2016 f250. Im looking for the black textured ones.
You can add shipping to 95943 into the quote.
Thanks, Cyrus
Sent from my SM-G965U1 using Tapatalk
sunrisefordparts
Thanks, Cyrus
HC3Z9E464A - List $20.33 -- your price $13.42
grill pieces - List $36.78 -- your price $26.48 each
+ tax
shipping will be $9
thanks,
Sean
Quote 564411
