sunrisefordparts
- Joined
- Jun 14, 2011
- Messages
- 5,453
- Reaction score
- 7
Need a price on a alternator bracket for a 6.4 8EA60441
bracket list $158.47 sell $118.85
what yr/model truck you working on
1988 F350 Diesel 2wd
hpop list $626.67 sell $517.00 no shipping charges
05-07 header panel list $233.03 sell $174.77
All parts for 2005 F350 SRW. I want to rebuild the front end.
upper ball joints x 2
lower ball joints x 2
Yellow o-rings x 2
Axel Dust Seal x 2
Wheel Seal x 2
lower ball joint snap ring x 2
Upper ball-joint nut x 2
lower ball-joint nut x 2
o-ring kit (includes 1 snap ring and two black hub seals) (5C3Z1K106AB) x 2
Cotter pins x 4
Studs to connect hub bearing to knuckle x 8
Nuts for above studs x 8
Hub Unit Bearing Assembly x 2
Inner tie rods x 2
Outer tie rods x 2
the ball joint that the trac bar connects to x 1
the drag link ball joint that connect to the pitman arm x 1
anything else that I might have missed?
Thank you! I just thought of something else I need... The o-rings to go with the HPOP that need to be replaced, I already have the HPOP screen from when I had my '03. If I could get a package price, I'll place the order tomorrow or monday. Thank you!
-French
-French
Upper tailgate lift/lower struts (2) for an '04 Ex. Thanks.
Can i get a part # for this? Thanks
And all front end ball joints for 2000 F-350 4x4
How do I go about placing an order for the HPOP and O-ring kit? I'm ready whenever you are...
-French
TRM 1640 Shipped to A2V 2B9 Canada
TRM 1640not following what part your looking for
TRM 1640
That's the part number I was given by local dealer for an automatic transmission for a 2002 escape xlt V6 4x4.
Thanks
Can somebody check on my order status? I placed the order on monday and the guy I was talking to said he would call me back with a shipping number shortly... Never received a call... We are really needing these parts!
Name is Joshua French
Thank you!!!
