Aaron S
- Joined
- May 22, 2011
- Messages
- 169
- Reaction score
- 0
I can't say I noticed when it started, but I have noticed a vibration around 2900 rpm and up. The truck runs fine and is smooth otherwise. The vibration is there if the engine is under a load or not. It has done it with two different transmissions and flex plates.
I haven't run it up to that rpm in park though to see if there is any difference. I should probably try that and then pull the belt and try again. The crankshaft damper/ balancer looks ok.
Any ideas for things to try would be appreciated.
Thanks
Thanks
