Ok, I had a shop install a rough country 3 inch lift with dual steering stabilizers up front. truck rode great and steered great! Wasn't hight enough. Soo... did the 4.5 inch lift on the front ONLY, rear has a 4 inch block like it did with the 3 inch lift, but now the bump steer is DANGEROUS!! he has the radius drop brackets.. The radius arms are in the top holes as was they when the 3 inch springs were on there.. any suggestions. Yes, it has been aligned.It doesn't pull any to the left or right, but DAMN when you hit a bump you better have a death grip on the steering wheel!!
First in with the 4.5 inch.. 2nd is the 3 inch
