3 transmissions in a month
ghohouston
Lewisville,Texas
No ***king way! That cant be true. Was it cheaper since it was a pos?
Not even trying to get into another argunent with you, BUT, heres the story. I ordered it from cary (obswiz) on psn, before I came over here, and somewhere in the mix, even though cary had in a pm what my mods were, it got built to stock specs. But like I said, im glad I went with them for the warranty. Im not saying theyre gods gift to the 4r100, mistakes can happen with them as can with any other human being, but was not at all a p.o.s. its now in a truck with 300/200's I believe and doing fine.
Layson
I didn't think they build one to stock specs... just sounds like you got a bad one from the start.
ghohouston
Lewisville,Texas
Thats what I was told, brian said as soon as they/ he tore into it, that it was built for a stock truck, maybe said like 300 horse, I dont remember for sure
I just find that hard to believe since.everybody always says Brian only builds one trans. So either that bit of what has become common knowledge is bs or they are looking at the intended vehicle of install and cutting corners on the build.
always-strokin
Interesting points you raise there....
4duggan
Bloodymore , Murdaland
Bought mine used from lildevil.
Brian asked me the day mine made it into OR what I was doing with the truck and HP.
Said he was gonna pull VB back out and make adjustments to tame it to the level I was running at the time.
Have increased HP since and it still performs flawlessly.
So I have to agree with the 1 trans Built, if something breaks its upgraded when it gets back to him.
Just my $.02
Kylerf150
great falls Montana
Hey guys sorry for the absence!!!
Well I got the tranny back from John a few weeks ago.He found a internal leak on the forward drum which explians the reason why it burnt up so quickly.
Anyways I've put about 3000 miles on this trans and It seems to shift good other than one little problem I've been having.
When I first start it and take off I WILL NOT SHIFT INTO 3rd!!! Until it gets warmed up to around 100 degrees. Its demanding 3rd according to my aeroforce gauges. It just stays in second all the way to 48 MPH then it demands 4th and will just slip!!!Once the truck warms up it never has another glitch its only on the first start up or after the truck sits for 12 plus hrs.If I start my truck and let it run for about 20 mins eveything works great.
When it acts up Sometimes I can put it into N then shut the truck down and coast, start it back up and all is good. It will shift like it should. This works sometimes and sometimes it doesn't. Keep in mind its demanding 3rd everytime.
John wanted me to take the 2-3 shift valve out and the 2-3 accumulator plunger out then clean everything up really well. He is thinking some junk may have still been in there from the last burn up. I did this today but I didn't find any junk in the bores and the pistons moved smoothly in the bores after I removed and cleaned them. On the test drive I never could get up to a good speed to test it before it warmed up (damn traffic) but it demanded 3rd and it didn't shift when it demanded it.I will try again in the morning when there is less traffic and see what it does when i reach 48 MPH.
I have installed a New PMT2 Pcm, All new tunes From Swamps and from PHP which is what i'm running now. I haven't been able to locate a wiring harness for the transmission but i'm wanting to change it out just to eliminate that from the equation.
I'm seeing good pressure off of the test port. around 75-80psi while cruising and around 200psi at WOT.
Anyways I'm dumbfounded and don't know where to go from here. Maybe its the shift solenoid not carrying through or leaking at the base and not getting fluid to the right port until it warms up and expands. I found a write-up on transgo saying to drill 7 1/8 inch holes in solenoid body where there is a possibility for a cross-leak pressure build up on the voids that are not used causing bowing of the plate. It makes sense has anybody done this??
By the way Swamps found nothing wrong with the original tunes and they are a great tuner but I have a burner for my PHP chip so that's why i'm running their tunes.
Thanks Guys and sorry for not posting lately Its been a busy few weeks.
Kyler
Dieselboy.
Surrey B.C.
If you decide to go to a PCS Im here to help.
Sounds like you got some weird things happening.
If you ask Charles a question, pick your words wisely LOL
