04stroker
:whs: I was a little worried in the beginning this would be an air vs fuel debate but this is a great thread.
Are you still thinking of going bigger on the fuel side after our upcoming test?
Why would 30s not work? JD did 60s with 2.0pw and only lost 22hp I think it was so a decent tune and a half way working k16 should be able to I would think
Jd did 60hp nozzles which are 15%. The other nozzles in question are 30%.
Also keep in mind the parasitic draw of the extra pump. It will rob power (I suspect in the 70hp range at full tilt) so if you do an extra pump, be sure to get large enough injectors to justify the compensate for the added parasite.
Need pumps before nozzles. Could pull some PW out of tune to help keep rail inline but really just need more k16.
Does it make more power than stock injectors with a stock pump? if not, what's the benefit?
