30psi ICP= dead excursion! Help please
ktmrider
update: I have pulled the injectors on the passenger side and inspected the orings. The bottom injector oring on both #5 and #7 cylinders is alittle rough looking. Not smooth, kinds of pitted/frayed. All other orings appear fine to my eye.
Next, I got a little anxious while already under the valve covers, so I called up Full force diesel and ordered a set of 238 hybrids and and 6 positions ts chip with gearhead tunes. I hope thats not a mistake buying more go fast parts before I have confirmed the no start issue..... im a sucker for more power:) With that in mind anything else I should be looking at while im in this deep? I will replace glow plugs before Im done. Im kind of changins subjects on this thread but my turbo is stock with a wicked wheel in it, should I be looking for an upgrade with my new injectors, any suggestions? Other modifications currently on the truck.... adrenaline hpop, edge evolution(about to get replaced),afe stage 2 intake, afe blade runner intake, built tranny, 37in tires, 8 in lift
bad12jr
Honestly 38r for the turbo. The stocker isn't gonna be happy. I'd say the injectors will solve the problem with starting
Wayne
Twin Falls, Idaho
Just noticed this thread. Good to see you on here, Ross. I'm looking forward to seeing what the next justified mod will be now you will have enough fuel injector to overwhelm the turbo. 38R and a regulated return? To the 7.3 gurus: While I'm a fan of overkill, and know what I would run, what's the minimum SAFE fuel supply recommendations while running 238's at full tilt?
CSIPSD
Bend, OR
What ever it takes to maintain 60+ psi fuel pressure...
Some trucks get away with a completely stock set up and a regulated return... Others have to go full 5/8"...
ktmrider
thanks wayne
ktmrider
I now have all injectors out and am waiting for the new ones.... the other four injectors orings were about the same as the passenger side. The bottowm oring on a couple of them looked rough but the others all appear good to my eye. Is this common?
If I upgrade to a 38r, would that put me needing to do headstuds, valvesprings etc? what are the guidelines/ limits of these motors? Never have went beyond the built tranny, chip and hpop on these trucks
mandkole
Northwest
Ktm, do you have a black fuel filter ? The bottom oring failure will blacken the fuel. If not keep looking.
ktmrider
The X runs!!!! Wow it feels good to say that, it runs pretty mean too:) Thanks to all you guys for you input and ideas. It kicked my butt for way too long and I couldn't dedicate much time to work on it but its back going. I installed my new 238/100 hybrids and new glow plugs. I also installed a 6 pos ts chip with gearhead tunes on it. I also replaced the electric lift pump on the frame rail with another stock one... maybe I should have done something different but that's what I threw in. THANKS THANKS THANKS
So here is where the x sits:
Built Tranny
TS chip with gearhead tunes
238/100 hybrids
Adrenaline HPOP
Stock turbo with wicked wheel
AFE stage 2 intake
AFE Bladerunner manifold
stiffer fuel bowl regulator spring
37in tires/ 6in lift
amp steps
rear airbags
my initial impression with the injectors was wow! way more boost, power, and smoke. The bad part is the EGTs get hotter way quicker than with the stock sticks and the evolution. My boost used hit 20-21psi now it will hit 27 but then I back out of it because egts hit 1400
Whats your guys recommendation next? Turbo? which one? How much boost can the motor take without other upgrades? Thanks in advance. This does pull a 3 place snowmobile trailer, runs around town, and hits the county fair truck pull once a year
ktmrider
Also would like to trim down on the smoke, I like the power but smoke doesn't seem to make friends
CSIPSD
Bend, OR
Smoke is from lack of air flow... Also from what I can tell you live in the denver area? Altitude will kill you.
mandkole
Northwest
Nice. Good to hear the truck is starting and running well--that was a well fought battle.
Although you had the files written for your setup and location, they may need to be adjusted. Nonetheless, 27 seems low for a well sealed system on a max effort file-- you may want to run 20-25psi of regulated air through the intake system and look for leaks (boots, CAC, plenums, etc). Look for uppipe leaks as well.
