JCart
If I'm getting approximately 20ish+ on the high way with 265/75s, 4.10s and that POS e4od, what kind of increase would 3.73s and a zf5 swap gain me? Just curious
With all due respect that sounds a little optimistic especially if it's US gallons, for 4:10s and such short tires, are you sure you have those gears? I'd think you'd pick up 2-3 miles per US gallon with a ZF 5 swap. Not sure with 3:73's.
Why not first try some 285 or 305 tires? Each truck is a little different and having owned three best mileage on a consistant basis was my '96 F350 cc 4x4 with ZF5 285 tires, 150/146 injectors with IC DP and 3:55 gears, electric fuel, 1.0 exhaust housing and T Wildman tunes. I would get 20-22mpg (80/20 hiway/city) and get as high as 24 mpg (road trips empty) now these are imperial gallons though. When the truck was completely stock I'd get best 18 mpg.
Not really worth the dollars to swap to ZF for mileage (pay back wise) I don't think, but to rid yourself of the E4OD (if not close to BTS) then it makes total sense IMO.
jrc
