BOSS450
that is a very crappy design.
as the joints or bushings wear out you will get unplanned variable caster change under braking as the lower twists the upper link.
Bold statement
the axle bushings are same as OEM
the top is a Heim I don't think it will have any faster demise than an OEM bushing plus they do pivot much better
i could barley pivot my stock radius arm in it's mount after I disconnected it from the axle
True but the longer arm needs to be on the bottom. When you're braking the force will flex the huge soft bushings and cause the lower short arm to push up and want to twist the upper. Best way to solve that is together rid of the heim on the lower link where it ties into the upper. Don't get me wrong radius arms work good but you have to have 1 bushing somewhere if you want it to articulate without binding.
Binding ? Heims pivot within themselves but the lower heim should just be a caster adjustment and never move after its adjusted and the jamb nut tightened
or if the above is true it's not even a heim just a fixed adjuster ?
Dana 60 has 2 bushings on each side but those aren't going to allow much twist that is all on the upper mount ()can't see it but Heim?
all in all I don't see this behaving differently than a solid radius arm other than the adjustability and top mount possibly having better articulation (assuming the materials are strong enough to not flex)
comments above are IMHO
Why would they charge more to align a 4 l,inked truck, this is the same 4 link setup that dodge has ran for years now...
Tractor links for the win lol
Sent from my SCH-I545 using Tapatalk 2
Lol from PTO attachments to 4 link front ends, they do it all!
I hope that's a joke someone did. It looks like there are maybe two threads left holding them in.
