you didn't specify which morning...clever
Lol, sorry. Left that day on a backpacking trip down the Grand Canyon. With all the craziness before the trip. Totally forgot. I'll measure it today.
Jomax- can you measure the distance from the center of your wheel hub straight up to the wheel arch in the fender?
I'm 22.25" front and rear. Curious where the 4400# springs measure.
Ha! Thanks.
I expected to be lower, but not by this much. The first springs I tried were .5" lower than these!!
I've had this setup since 2013, and it's a bit rough at times. I think I could go back to stock shackles and 4400 springs to fix the harshness, but I'm not sure about the swaybars. I have hellwig front and back and the back one is for for a 2wd- need to call and verify fitment.
Or sell the truck. Really like new raptor.
I'm running a rear swaybar made for a 2wd.
Is your truck 2wd?
No- 4wd. There are signs of the bar rubbing the spare, but I think it only happens when a load is connected.
The 2wd bar will probably work at factory ride height.
Had springs made by Coil Spring Specialties. The first set were 3" drop with factory rate. Too low.
This set are 2.5" drop at 15% stiffer rate.
~1.5 - 2". Difficult to measure it, but probably right in the middle- 1.75".
Certainly not enough to air it out over speed bumps!
Awesome, thanks. I plan on making the switch pretty soon so wanted to make sure I had everything before I had it torn down and got stuckI got u bolts for a 2wd without overloads from ford.
Well, after lots of questioning I finally got the new suspension put on in time for Christmas! Went with 20x10 wheels with 305/50 Toyo Proxes tires and gotta say I love the way it came out! Thanks to everyone who took time to answer any questions I had and look forward to doing much more to it in the future![]()
Thanks!Nice! I didn’t know toyo still make the original proxes
