01PSD
Ok guys the transmission in my truck decided it no longer wanted to operate properly on my way home from work yesterday. I was leaving a stoplight at 1/2-3/4 throttle and when the tranny tried shifting into 3rd gear... it said nope. RPMs steadily rose until I let off the throttle... then it finally threw itself back into 2nd gear (harshly I might add.) 1-2 shift is fine and good, reverse is good, but no matter if I try manually shifting or letting it go in auto, it will not shift into 3rd gear. The RPMs rise but the truck decelerates until it finally goes back into 2nd gear. No codes (at least I couldn't see any with Auto Enginuity) and fluid smells ok still.
