Buellstunter
Been having trouble with getting my truck into 4wd. It still has factory hubs and truck has 215,xxx miles on it. I bought the truck in may. I tried the 4wd and it worked. tried it a few weeks ago in the snow and nothing then all the sudden I noticed it was working. so I tried using it the other day again and not working again. With hubs in auto I turn dash switch to 4hi light in dash comes on but doesn't engage in 4x4. So I manually lock my hubs switch to 4hi and the light in the dash comes on, but still no 4wd??? So I craw under the truck in 2wd and can spin front drive shaft by hand. turn switch to 4hi and front drive shaft locks in. so I assume the shift motor and the transfer case is working. so I check all the vacuum lines with my vacuum brake bleeder. hook it to the line from the vacuum solenoid on pass front fender that goes down to both hubs and it pumps up and will holds vacuum. so I'm assuming no leak. have someone flip the switch to 4hi and the vacuum solenoid pulses can hear the vacuum canister loosing air and the vacuum pump kicks on. seems like the system is working properly, so I'm guessing it is some issue with the hubs but not sure.:shrug: can Anyone give me some pointers on what to try/check next? thanks in advance!
