4x4 hub seals
Lassie
Tenn River Alabama
Ok I got the hub off. Now trying to get the shaft out. I am going to oder new seals and O rings.
Can you help me 200007.3?
Once the hub is out, just pull the shaft straight out. The seal will come with it.
As far as that dust seal goes, you can change it, but it will probably be hanging again in a few thousand miles. I'd pop the old one back on. Take a look under most of these trucks and you'll see that dust seal hanging on the shaft.
Zmann
lets get some info out the dust seal has been updated for a few years and doesn't sit on the axle anymore it sits in the axle shaft
the knuckle seal is a bit of a chore to get out and usually is damaged and needs replaced using a special tool
Cajunhunter67
Trout, La
Well thats where Im At. The seal that comes out with the shaft..knuckle seal is bent to hell. I have a new one, but I dont want to ruin it installing it. Looks like its pressed fit on the shaft? Any ideas?
91turbogsx
Gardner MA
You need the tool. Or many people make there own.
OTC 6698
6
6.4stroke
Guest
I have the same problem accept passenger side. I can hear air escape when I lock it in.
Cajunhunter67
Trout, La
I couldnt hear air, but I have a hand help vacuum pump. Driver side wouldnt even build vacuum. should finish this tomorrow. I gotta put together a tool to install the knuck seal. Hopefully I havent already damaged it. Uggh!:doh:
Cajunhunter67
Trout, La
Well guys, I replaced the knuckle seal, and the Hub oring. I used assembly lube on all of it. including the red oring on the Auto/manual selector assembly. No leaks and works with the swicth as it should. Appreciate everyones input and help.
Zmann
sorry I missed your question!
on the old trucks u made a tool using 1 1/2 inch pipe and a floor flange and cap 05 up u can make the same using 2" pipe and flange but u need to turn the flange diameter down a little also you don't thread the pipe all the way into the flange or it will hit the axle before it seats the seal
glad u got it fixed
for anyone curious on the tool
here is the old style I haven't seen a write upon our style yet but basically just larger pipe and a different final "OD"
http://www.superdutypsd.com/axle_seal_tool.php
