PABowhunter
- Joined
- Sep 18, 2012
- Messages
- 715
- Reaction score
- 0
I am planning on five smoked led. As far as the spacing I always thought the evenly spaced cab lights on obs style trucks looked better than the cluster on the super duties.
But I've only seen a couple evenly spaced lights on super duties. Just thinking outside the box. Maybe I'll stick with factory spacing.
personally I would buy the OEM lights and just buy Recon lenses. but idk how much OEM ones would be.
After doing some research this may be the best option. Probably will cost a little more up front, but looks like they'll hold up better over the long run. Plus, correct me if I'm wrong, but I read somewhere to replace bulbs on recon lights you have to drop the headliner again instead of just taking the lens off.
Recons are LED. You more than likely wont replace them, but if need be, you just remove from the outside, pull the plug through the roof, plug in new one and resilicone everything on that light you jus pulled. But again, they are LeD and should be good for a long time.
Saw an oBS around here with Chebby cab lights, the single bar in the middle looked alright
...put a pic up of these 10 cab lights
