5R110 Billet Hard Parts
CumminsKiller115
Western North Carolina
I have 2 NIB Items for sale. Item 1 is a Elite Diesel Billet HD Pinion hub and the second is a Elite Diesel 300 Maraging steel input shaft. All this is for a 5R110 Transmission for a Ford Superduty.
$400 for the Billet HD 5 Pinion Hub
$300 for the 300 Maraging Input Shaft
Bought these right before Christmas and won't be using them as I am going with Twisted Diesels trans. If any further questions, call or text 828 808 4099
CumminsKiller115
I believe you use the factory gear from your factory hub. I have the pins for this hub, that allows you to hold the gears in place. There is nothing else that came with it from Elite.
EDIT: Upon further review you use the factory gear in the hub. Elite provide a "loaded"" or an "unloaded" version of the hub. This is the unloaded version so you need to swap over the factory gears.
