6.0 down on power and missing
cory99
My dads 05 6.0 has been acting up lately, it is down I, power and sometimes takes longer to crank than should. Have checked with AE and get the following codes. P0266, P0480 and P0528. Truck does need new batteries but even with them being fully charged and truck at operating temp you still have a miss that can be easily heard and seen on tach above 2k. All three codes continue to come back after driving for a while so assuming #2 injector is on its way out. Anythibg else to test before throwing injectors in it, truck has 170k so likely due anyways. IPR, ICP and FICM seem normal ranges but truck still seems down on power. I ran the power balance test with AE and didnt see any fluctuation in the cylinders and #2 code takes a day or two of continual ise before it cones back.
As for injectors seems most say Holders or Warren, are those the two to stick with? I run full force in my 7.3 and no conplaints but seen they dont offer as good warranty as other two for 6.0.
