Monster12valve
Damn, that looks awesome. Prices yet?
Id imagine the same way the bpd kit does. Mounts the same but doesn't get hot sitting. The big air to oil cooler takes care of that.
The BPD kit doesn't require the removal of the condenser coils. Last i knew...there's two mounting options for the cooler. Either behind the front bumper or behind the A/C condenser
check again
it's 1 option for mounting and it requires the condenser out
or you can get creative but it's not recommended because you may puncture the condenser with the tapping screws
also if u have the wrong style PS cooler you have to replace it
They musta changed their kit around then...cause they did have two mounting options.check again
IDK why the BPD inside the bumper original version is gone but I bet it's cause of air flow from the fan same reason I think it's not in front of the condenser now
Jarrod as you know OEM is a puller fan it's going to pull the most air from the path of least resistance so up high and last in line is what I see from this unit
not saying that may not be fine but they will need to test it and I am sure they will
they have a way to do it without removing the condenser all the way/
I don't get what you mean when you say "or you can get creative but it's not recommended because you may puncture the condenser with the tapping screws", because that is what the instructions call for you to do, mount it to the condenser.
Here is our Filter for the 6.0 and 6.4 kits... E Series 6.0L Filter housing. We are in the process of machining the custom Plates for the In/Out of the filter head, ORB fittings made from billet so it will be easy for the end user to create their own setups. The plates will also work for the van oil head on the oil cooler, so you will also be able to use the OEM oil cooler and relocate the oil filter and still use the fuel bowl by using the van parts... stay tuned.
