6.0 performance parts
Cutting-Edge Diesel
Newkirk, OK
What I currently have
190/100 used $1000
6.0 fass fuel pump kit used $400
KC turbos stage 3 polished $1800
195/150 injectors $1000
500/400 8mm hybrids $2300
DC power 320 amp alternator $550
6.0 block fresh .020 bore with new pistons and polished crank ready to assemble $1000
RCD push rods $150
RCD high rev valve springs $400
NEW Promaxx bare head with wirerings $600
Strokersace
Towanda, KS
Will those push rods and valve springs work on a 6.4? Do retailers come with the springs?
Cutting-Edge Diesel
Newkirk, OK
6.0 ATI damper fresh from ATI $250
S472/83/.90 t4 cast new in box $700
6.0 195/150 injectors used $1000
6.0 190/100 injectors used $1000
500/400 WDI 8mm hybrid injectors $2000
Promaxx new bare head with orings$700
S475/96 t6 cast used $500
S591 t6 cast used very little $1850
Hypermax 4.1" turbo (104mm) t6 open $4000
S472 sxe .90 t4 $1100
FASS 125gph 6.0 kit used $400
Rcd stage 1 push rods 6.0 $150
Rcd high rev valve springs $350 or with push rods $400
D.C. Power 320 amp billet alternator 6.0 $500
6.0 standard bore delipped pistons used $250
