We are not saying they are not component balanced, but is it not better to have it balanced as a whole? Its your motor, stick a screwdriver in your turbo for all I care.just don't go telling everybody that you can just go around swapping wheels and everything will be fine. not all compressor wheels are component balanced as well. and comparing them to a tire...
Sent from my DROID BIONIC using Tapatalk 2
Im done here. You can't balance the rotating assembly of a factory 6.0 turbo when it is assembled, you dont know what you are talking about.
I said that not all turbos are component balanced, but that 6.0 turbos are.
I should have used a reference a little easier to understand aparently, you arent getting it...
To the OP, I think that your turbo is good based on what you are describing, just make sure that the thrust play is good, and that you dont have any housing interference
