6.0 UPGRADED FUEL SYSTEM
TurboV
Chenoa IL
I went with the Irate duel 7.3 SD pumps on my 6.0. That's how you keep stock reliability and run bigger injectors on a 7.3 or 6.0 IMO
Sent from my SAMSUNG-SM-G900A using Tapatalk
FarmWithAFord
Indiana
If you're gonna go with an AD, I would say go with either the 150 or the 4G. Those are the most reliable. I have the 150 and it performs awesome.
MaxdLaw
Granite City IL
I have bigger injectors and I went with a air dog. No although they were replaced for free..... This is my third one. The last two have completely quit working and wouldn't come back on and almost fried my injectors. The one i have now I had to take apart and unstick the motor once before. I will be going with a fuel lab eventually.
03cody
Bethany Illinois
I have a 6.7 pump on mine. Had it for about 4-5 months now and have had no problems. Hold's pressure extremely well with my 205/100's too. I plan on getting rid of the fuel bowl and adding a finer micron filter after the pump, run it to a Y, then to the heads while I have the engine out.
You wouldn't wanna throw up some pics and tell us how to do the 6.7 pump would you?
04cr450
harford county, maryland
another option is a rr, oem hfcm paired with a 6.4 hfcm as a lift pump, then a sump.... i have this setup and holds 205/75's. very happy with it and reliable. the 6.4 pump is the same wiring harness as the 6.0 pump- just tie into the factory wiring and your done.
shmoozer
You mind throwing up a couple pics of that? I assume you're still using factory filters as well?
-KCCO-
