6.4 Advice on buying
Matt
Minnesota
The one I was looking at they came down to 34,500 on, I still think it's a little high, but it seems all used 08-10's are high right now. Maybe they'll call me next week with a little more off, but I'm not holding my breath.
Matt
Minnesota
Found a '10 F350 ex cab short bed lariat loaded but no sunroof or navi. 24k they want 34g for it.
Just saw a very similar truck, but with 37k on it for $33k on autotrader. Still seems high for an extended cab, but not horrible either for such low miles.
Kent94
Massachusetts
Yeah that dosent seem to bad for that low of miles. I guess it depends where you are to. Up in Mass thats cheap. The local ford dealer has a 2010 crew cab lariat with 40k or so they want 43g for it. Rediculious!
Brake Weight
Southern Miss
I'm looking at one also. An '08 f250 CC LB with 85k miles and they're asking $30k. It's been on the lot for almost 2.5 months and I'm thinking of offering $25k and see how that goes.
Mdub707
Mohawk NY
id try and chew him down some.. mine was 37,900 and i got it down to 36..
LOL
he started at 39900 a month ago and just dropped to 37900. i said if i bring cash what will he do and he said 36. i dont kno how much more i can push him. comes with two sets of wheels but its 4 hours away from me.
So is it supposed to be a harley truck, or is it just a regular truck with harley wheels? If it's supposed to be a harley, it doesn't have the correct side vents. Likely was in an accident, and maybe fixed with random parts?
VanoFord
Sugarland, Tx
my 08 F350 CCLB Lariat i got in Nov was on the lot for $31k. Not sure how long it was sitting there though. I walked out for a bottom price of $29.5k and they threw in a 2yr/24k warranty (and in the 4.5 months i've owned the truck, i've already put on 12.5k.)
Brake Weight
Southern Miss
This one has the mounting brackets for a 5th wheel and the plumbing for a bed mounted tank. I couldn't see any wear or abuse. But having those two setups tells me he most likely did some heavy towing. 35/1250s on stock wheels with a leveling spacer. Has a slight reverse rake.
How does the 6.4 compare to the other power strokes? I've read up on the 6.0 and know about the 7.3. Just started reading up on the 6.4 some.
