6.4 aftermarket build for sale
Montrose,pa
OR SALE
Blocked bored .030
Carrillo rods
IH Maxxforce Coated pistons
zero crack heads, O ringed, magnafluxed, decked, 5 angle valve job, new valve guides, and elite (130#) valve springs
pusher cam from SADP
Ported intake manifold
ARP head studs
SADP push rods
SADP lifters
OEM oil cooler
OEM rockers
6.4 manifolds
6.4 up pipes
RAE HPFP
New hpfp harness
6.4 stock injectors tested/flowed
EGR ******
No limit air intake
All new cold side piping and elbow
New front cover
The motor has been flawless and has run on lubrication engineers oil. There is absolutely no tweaks at all in the motor.
I may be forgetting some additional things. I’m looking to sell the motor altogether. Everything is there for a 900+ rwhp capable build except the dual fueler bracket, and pump as I sold them to a friend previous to this post. I have well over 20k in the build without labor. Asking
$15,500 for the complete motor without turbos
I also have a 76 mm precision ball bearing low pressure turbo and a 68 mm vgt custom built hp turbo. All the custom piping and boots+ clamps are included. The t4 mount will be included as well
10,500.00 for the setup
Midwest diesel stage 5 fully built transmission and converter
Looking to get $8,000.00
Tial MV-R wastegate brand new- $465
New Turbo smart blow off valve -$350
Dana 80 shortened to stock width of a single rear wheel 08 f250 with Yukon axles and 3.73 gears.
$3,200
All prices are OBO!
