Stroker04
I'll have that next week and we'll probably start with a pre-sale special. I'll post in the 6.0 IC thread. Thanks.
Cool thanks
What is the final width of the 6.4L Intercooler...
Are you guy getting close to getting it done or is it still a few months out
Note 3
I did not mean it in a bad way. You have already done alot and keep up the great work. I was just trying to get a time frame.
Note 3
Does anyone have any info from testing with these?
any updates on these bad boys
Just to chime in. Before I had the intercooler in I would see anywhere from 203-207 oil temp at highways speeds at 1900-2200 ish RPMS 68-72 MPH and coolant would be 195-199 unloaded. And to be honest I did not notice a difference between before and after. The EGTs were between 110 and 180 cooler but the oil and coolant temp I did not notice a jump in temps if any maybe 1-2 but that could have been foot related from testing the EGT drop. It might when pulling a long long hard grade but I haven't run into any noticeable temperature increases yet since the install.
Thanks for the update!
I follow that thread in the 6.4 section too and did see that which is promising. That was about my only concern with a larger/thicker IC was blocking too much air. But it seems its not effected at all so I'm gonna go place my preorder right now. Keep up the great work!
