6.4 part out
Shafer171
Michigan
Dynamic diesel stage 2 cam 500
Dynamic diesel stage 1 push rods 100
Dynamic lifters 100
Stock rods with arp bolts 500
Rae hpfp 500
Set of heads with valves and springs 1500
Set of a1 studs 300
Rcd work stock turbos 2400
Turbonetics 45mm wastegate with rcd up pipes and 6.0 manifolds 1000
Midwest dual fueler kit with Rae pump 2000
Stock fuel cooler set up 250
Everything was new in the build this last spring. Less than 1000 easy miles on it. Block is cracked from over torqueing studs. Buyer covers shipping Would rather not ship the heavier items.
Shafer171
Michigan
Heads sold
Still have:
Dynamic stage 2 cam 400
Dynamic stage 1 push rods 100
Stock rods 400
A1 headstuds torqued twice 200
Rcd work stock turbos 59/71 2300
Turbonetics gate 300
Midwest dual pump kit with Rae pump 2000
Stock fuel cooler 200
Shafer171
Michigan
Some pics
