6point0damn2004
Interested!
The 74mm we have been testing is insane. If you did your homework you should have awesome results
Yeh, I figured it would be a monster, glad it's working out for you guys over at RCD. When I got into this you guys were and still are respected by me, I liked your products. Keep up the good work on the powerstrokes.
Thanks Adrian. You going with a larger turbine as well?
I was planning on it since it specs out close to a gt4202 turbine. If it doesn't spin the compressor easy enough I might go up in size, it's all up to the testing turbo, and backpressure numbers. I love my Garretts so I'll use whatever Garrett internals I can, and some custom compressor wheels. You guys get that big in the stock compressor housing or are you using a different cover? Like I stated before I'm using a stock compressor housing, and that will take so doing, you know me got to be drop in, no extra tubes and pipes.
Yes. It will be the stock appearing housing like always. We base our turbo designs around midwest truck pulling so its gotta look stock. The 74mm is a squeeze
