6.4 Swap into 7.3 truck using 7.3 Controls System From CR 7.3 thead
neverkickn
AR
currently not for the twin pump system, since the IDM8 (not a modified IDM, but a purpose built piezo injector driver) 'grabs' the FDCS/CID signaling from the factory 7.3L PCM and then outputs the appropriately shaped signals to fire the 6.4L style injectors..with a single event
We are concurrently working on 2 similar, but separate projects for a single pump CR system (mounts like our Gen3)...as well as a standalone controller to run a 6.4L engine in any chassis...
this last controller will allow for user end adjust ability of PW, timing and pressure based off of very few sensors...(pedal voltage, MAP, rail pressure, CPS, etc) initially for competition oriented vehicles...however as time progresses we will be able to incorporate more interpretive software that would be geared toward milder setups.
Very cool stuff. Your job is the chitLOL
golfer
lmao...you'd think...
in reality...I sit in an effing office all day answering Q's about ***n FICMs, and emailing estimates/quotes, etc...
it's the other 22 guys here that make chit happen
Tree Trimmer
you get to sit in the air, and talk on the phone, and make the big bucks, while everyone else slaves around the shop working. :D
this is where the boss, can make that executive decision, and tell a underling to go sit in the air, and you go slave in the shop......
