Found this on alldata...
Turbocharger
Maximum high-pressure turbine shaft axial end play............0.20 mm (0.008 in)
Maximum high-pressure turbine shaft radial shaft movement.....0.89 mm (0.035 in)
Maximum low-pressure turbine shaft axial end play.............0.20 mm (0.008 in)
Maximum low-pressure turbine shaft radial shaft movement......0.89 mm (0.035 in)
