6.7 fuel pump on 7.3.
campbellflage
Hudson, FL
OP, got a company working on the logistics to plumbing this thing in place, awaiting to hear back from them (also waiting on the ok to put theirname and quite frankly the best customer service I have ever dealt with on blast)... more to come soon.
campbellflage
Hudson, FL
Just got off the phone with Marty at Marty's Diesel performance (well yesterday) and my fuel system is just about complete, should find out more on monday. Went with 1/2 inch pickup #8 to the 6.7 pump, to post pump filter, to engine reg return then #8 back to the 6.7 pump to pick up water removed on the first pass then back to tank. Should be a good setup!
that confused me.. so you're sending fuel to the motor from the pump then returning it to the pump?
dsberman94
Pennsylvania
Why would you want the water to go back into the tank? Won't you end up with a tank full of water eventually?
campbellflage
Hudson, FL
I guess I could be wrong maybe it doesn't send the water back to the tank, but how do you think the 6.7s do it, their tanks don't end up full of water..?
dsberman94
Pennsylvania
Without looking anything up I would think you'd drain the water out since the HFCM is a separator and then any excess fuel would be returned to the tank. Since a HPF system is ridiculously picky about having water in it, they wouldn't run water back into the tank. They want it out of the system permanently. IE, you draining the separator.
campbellflage
Hudson, FL
That's probably how it works, it's a stock 6.7 pump brand new I just wanted to give it shot, gonna pick up some 250/200's soon so we will see how much it can handle
WILD_PHIL
East TX
Did you find anything that told you the flow capabilities of this pump or have it bench tested?
E99 F350/zf6/guages/arp/comp/stellite/ billet wheel/ bellowed... Need more fuel and more air.
Bluke
Colorado
The 6.7 will capture water in the water seperator until it is full. After so it will ship the water back to the tank. In theory you could have a tank full of water but that would mean you never drain your separator.
campbellflage
Hudson, FL
I can't remember the gph, its 55psi minimum, 120psi max pump with lots of flow.
this:
"The low pressure fuel pump
supplies approximately 3 times the
maximum amount of fuel required for
combustion. The excess fuel is used
for lubrication and cooling of the high
pressure fuel pump"
I think its gonna be plenty of fuel
spot on man. good post!
campbellflage
Hudson, FL
Rest of the kit shipped today, should have pics up on a few days. Gotta say dealing with martys diesel has been awesome! They call almost everyday just to give updates! Great customer service
