6.7L Powerstroke Turbo Kit Update
bricewise
Yes, We will offer two options. Basically the same billet turbo, only a turbine housing option at this time. A high altitude option will be available upon request. We may offer more turbo options in the future as we are always testing for better parts. We actually have new one's to test here right now, we just have not had time:(
No worries. Was just curious. Last question, I promise, the universal 40mm waste gate you guys have on your website, will it fit on the 6.7 kit? If so any welding required?
HS-MotorsportsZane
Ask all the question's you want:) No worries...... Yes that gate will directly bolt up to the manifold. It was put in there for guy's that may want to do compound turbo's and or NOS. We are planning on having a down pipe made to bolt up to the wastegate, but as of right now we have not. On this first run they will exit to the atmosphere. We did make the wastegate exit line up to the down pipe, so a little hole and some welding would do......
HS-MotorsportsZane
Oh, Also if you don't need to use the wastegate provision on your initial install, there is a simple plug and clamp provided in the kit to block it off...... If you change your set up and need to use it later it would be very easy to do so........you know.. in case you may need a triple turbo set up one day:)
jordan572
Pump you guys up! You just can't deny this whole setup,
HS-MotorsportsZane
We need to upgrade your compressor housing Jordan...... You have some more of that paint?:poke:
jordan572
I'll send some with a little project that should be on the way to Utah next week. That stubborn bald guy is convinced its a bomb painted ruby red. Enjoy your lasts days alive, big boom coming. :swordfight:
bricewise
Work has been killing me so been too damn busy. Anyways, you guys plan or want to offer any discounts on low pressure fuel system, turbo and waste gate?!?! $8900 is steap!!!!
HS-MotorsportsZane
Yes, We do plan on putting some package deal's together if multiple kits are purchased as a system. We are working on some new website things this week and should have something up soon.
quickid71
Just did an install on one of these kits and it was absolutely perfect and trouble free. The quality of each and every part is testament of extensive R&D! The truck ran extremely well when we were finished. Now the question is- dual pumps for an extra 100 hp? Very tempting.....
DWhite
Oklahoma
That video is taking me back to my 04 whistling 6.0 days and is making me want to buy one of those kits.
