JDub
Life has changed and I haven't ended up using this like I had planned to. Tank was installed but has never had a drop of fuel in it. Just don't need it. Tank has an electric solenoid that allows you to open/close fuel transfer down into the main tank. Also has a bung on top for an external pump for filling equipment if you wanted to. Best part is, the brackets hard mount to the truck, but the tank doesn't. So the tank can be removed from the bed in less than five minutes without tools if you need the bed space. Will fit any fullzie truck and under a tonneau cover as well.
These sell for over $1400 new with the options mine has. I'm asking $900 and could help with delivery depending on distance from Ogden, UT.
![484674_10200187521226269_1330588106_n.jpg](/proxy.php?image=https%3A%2F%2Fsphotos-b-dfw.xx.fbcdn.net%2Fhphotos-frc1%2F484674_10200187521226269_1330588106_n.jpg&hash=20c6e8867b0a7dc52223919c88bc0f97)
