600hp OBS 7.3 oil filler setup
turboblake
Ccv= crank case vent
I may have a harness for you
Oh ok gotcha. It still has the CCV on the drivers side valve cover attached to the intake tube so I'm not sure why he had that galvanized breather setup on it, but it was total crap. I already replaced it with the old oil cap
turboblake
By the sound of it I hope you didn't pay a little extra for the non existence ponies the guy said it had
I managed to get it for a pretty decent price. I've got a guy here locally that's gonna help me build a new fuel system for it so the stage 2s will actually do some work
You just need e-fuel. Stage 2s will feed just fine through the stock fuel bowl. If your on a budget that is.. if not then build away.
bluedge8
Champlin MN
Yeah buddy. Took me a while to wrap my head around that one too...
Doesn't seem too hard to understand, this is the way I understand obs' stock fuel system:
fuel pulled up from the tank to the fuel pump- first stage
fuel sent through the filter
fuel sent through the fuel pump second stage ( same pump but different section)
fuel sent to rear of heads
fuel sent to fps
fuel sent to tank
the fuel bowl was only meant to see about 15lbs pressure
fuel sent to fps
fuel sent to tank
Holy fuggin chit
I learned today that obs trucks look bada $$ if they are kept up. Saw a green cclb with nice wheels and tires and it had some mods done. Gotta love it.
ghohouston
Lewisville,Texas
fuel sent to fps
fuel sent to tank
All I meant was it took me a while to understand that the bowl will crack from added pressure. I wouldn't have ever guessed that the metal would be thin enough for that to happen.
Yea. I want one. I found a crew cab short bed with 125k at mj autowerks here locally and he wanted 12 grand. It was totally clean. Buuuut I want a longbed.
