strokin6L
Wasn't MPD sending turbo drain oil back in through a glow plug hole?
Yes... #1 glow plug hole.
Ok. Should I just order up a 45* -12 fitting from summit? That seem to work the best?
Also, can I keep my oil filter in the stock spot? Was talking with a guy and he said it had to be moved, at least the way he ran his plumbing. And are the up pipes divided or both go into the high pressure?
No need for a divided housing on the low pressure. There is no divided pulse to each volute making it less of an issue, the drive from the secondary into an open housing is enough. Not the same for the secondatry:thumbsup:
Maybe it's just the wording but it almost sounds like the OP is asking if the up-pipes go to each turbo? I'm not sure, just sounds weird reading it out.
Whether it's divided up-pipes or not, both sides feed the high pressure turbo. You probably already know this, but it sounded confusing LOL
Yea thats what he is asking. Not necessary to relocate oil filter. Just another cost to add on. OP, turbine side: divided up pipes> secondary inlet> outlet into primary inlet> primary outlet> downpipe/exhaust/tailpipe. Comp side: air filter> primary inlet> primary outlet into secondary inlet> secondary outlet into IC> IC into engine
I think if you where the one talking to me about one of our kits on facebook then yes you have to relocate the filter that comes in the kit like I was talking about to you.![]()
Sent from my iPone sitting on the crapper
not cooling both stages but with the big turbo doing most of the work, its a very very easy way to avoid the cluster*** of piping
MPD had a real simple way about routing the piping which was very intelligent, primary in to the intercooler, then out of the cooler into the secondary, then out of the secondary right around the oil filter in a U shape right into the intake elbow which was cut and spun around. Youre not cooling both stages but with the big turbo doing most of the work, its a very very easy way to avoid the cluster*** of piping
This doesn't look any less cluster****ish and still cools both stages...
