alradco
- Joined
- Jul 26, 2012
- Messages
- 953
- Reaction score
- 0
How much power does your truck make?
We can supply you with the entire rebuild kit. It would include pistons, bearings, seals and gaskets, glow plugs, oil cooler, and low pressure oil pump. We can also include fire ring head gaskets. We do the machine work for the fire rings in house. It is VERY critical that the surfaces be flat/true, and the depth be correct. I could recommend doing both the heads and the block.
We use Swain Tech Coatings for coating our pistons and bearings.
We can also coat the wrist pins and piston rings. The wrist pin coating provides less friction and the piston ring coating provides both lower friction and better sealing.
Also, make sure that whoever is doing your block work can torque plate hone it. And make sure that when you're filling the block that all the main studs and head studs are torqued as well.
Let me know if we can help!
Soooo still waiting on replies for parts, going to half fill, main studs , head studs , cut and coated pistons, Carrillo , balanced , girdle , cryo
Hopefully it'll hold a 1000hp once , not sure on the fire or o-ring yet having a hard time finding a machine shop I trust in nor cal most won't touch a diesel and shipping is a hassle and a lot of money lol , any more info do's or don't are appreciated!
Butte county , near chicoWhere in Nor-cal are you?
