7.3 mild power build
TARM
Happens so often unless its something OBS specific I do not bother pointing it out. But I do like when things stay organized so they are easier to find for those few that are willing to use the search function LOL
pretty simple and relatively cheap... you need a clutch to hold it.... 238/100, t500 hpop, d66, and a good e-fuel pump. i get most of my stuff from beans but many vendors on here can get you set up..
TARM
238cc/100% hybrid injectors
910 comp cams valve springs and shim kit
GT38r Turbo
Regulated return fuel system
Push rods (optional)
H1 or ARP head studs (optional)
4" turbo back exhaust
6637 or other perf air intake
Gauges (boost, trans temp,EGT)
PCM Chip
Proper clutch or built auto trans
Power range: stock to 500hp based on tuning
or what tarm said... but instead of a 38r and all the parts to switch a obs over to a sd then go with a d66... im pretty sure the op is asking about an obs. even with the superduty i would go with a sd66 from beans... cheaper then a 38r and has the same power potential..
TARM
Yep I agree forgot it was an obs right after I posted I knew it was :doh:
Either a d66 or just go to a full t4 kit but that adds about double the cost to a turbo.
