7.3 performance parts
03lariat7.3
RCSD
SOLD:
ARPs, springs, rods,
IDM, chip
Turbo, upipes, pedestal
Everything else is up for grabs, shoot me an offer.
Almost forgot I have the riffraff tooling to remove and install in cups on the 7.3 heads. I used them once, in like new condition. $250 shipped.
HPOP disconnect tool available too.
nasty6.6
San Angelo, TX
Possibly interested in clutch/flywheel and injectors, do you need cores? is the flywheel and dual mass or a single; and is the clutch single or dual disk?
03lariat7.3
RCSD
Clutch and flywheel spoken for. Still have the injectors, no cores needed.
03lariat7.3
RCSD
Need these injectors gone!! $1200 shipped!
Still have numerous parts, hpop, SD exh manifolds, fuel bowl, RR fuel system.
Riffraff injector cup tools, $200
Make offer on all parts, I will cut you a good deal but I'm not going to give it away!:swordfight:
Do you still have the injectors? If so pm me.
Powerstroke 7.3 work in progress !!!! Yfz450 intake exhaust jets + lots of other goodies!!!
Vw jetta tdi straight piped 55 mpgs!!
n54power
I'll take the stancor
Do you have a picture of how you Installed it using the shunt?
03lariat7.3
RCSD
Still have numerous part:
1-17* HPOP w/ gear, lines and IPR. $100
NAPA alternator, used approx 6 months. $50
Powermaster Starter, 1 yr old. $50
Dieselsite RR w/o bowl delete. $200
Riffraff Injector cup tools, near new, can rent if anyone needs them. $200
SD exhaust manifolds, can sandblast for extra $30.
Make offers!
03lariat7.3
RCSD
Is the starter the one like summit sells? Works fine?
Yes, I bought it from jegs. I found the receipt and was purchased Jan 2013. Last used Nov 2013. That's the second I had and had good luck with them. My last one lasted over 3 years.
03lariat7.3
RCSD
Also still have the long block for sale, head gasket out around #8 cyl. The engine was not cooked, caught it in time. Could replace HGs and run it or would be an excellent builder engine. 190k on engine. $500 and you figure out how to get it home.
