David N
I have fuel system, hybrids and a 38r, I'd be willing to try one when they come out.
Curious to hear about this, will you have before and after runs? I have a set of AC injectors with 100% over nozzles and will be running a van turbo. So I'm thinking if this wheel is can produce it might be perfect for my setup...
A van turbo with a 38r batmowheel should outflow a stock 38r, but you would have to modify the compressor housing to fit the larger wheel. It would be a Super D66-Batmowheel edition.
Got that setup now minus the batmowheel. I am already balls deep in the stocker so what's another four hundred........LOL
Quicker spool-up, increased power and lower egts were getting ready to dyno the stock 7.3 batmowheel this weekend
Would this wheel be comsidered clipped? I know our work stock class doesn't allow tapered of clipped wheels.
Any results on this or the 38r yet?
Dumb question what is a batmowheel. A new intake wheel for the 38r ?
So it's a fancy looking wicked wheel . Wonder if it will make the 38r any louder.. And 50-100 hp increase seems hard to believe.
When this **** becomes available, im gonna get one.
A 1.15 housing for the 38r and this should be nice.
I wonder if the batmowheel is heavier or lighter than a 38r wheel? If its lighter, it should be a little easier on the bearings right?
If you could figure out how to add a ballbearing center section for another grand, then you could have the baddest turbo ever for a stock pedistal, plus you would probably only have 4 grand total into a stock type turbo, lol.
You can have stock center upgraded to a bb unit.
Wonder how a batmowheel will do on my e99 van turbo. Or how well it would flow....
