7.3 questions
Freightshaker
Evansville
So say if you were aiming for a mild build and it is time for injectors. What would be a wise choice on say a pmr motor- near stock cc with 100% nozzles?
Buffalo444
Laramie, WY
Nothing over stage 2's (160/100%s) IMHO. But then again, I have first hand experience with stock PMRs blowing out the side of a stock engine with stock tuning....
CSIPSD
Bend, OR
A PMR motor I would go with a 160/100 injector... Even a stock set of hybrids 230/100 range would be fine if you had good tuning.
oneturboforme
okay i think i have the concept of the fuel system down thank you guys
now what about turbos, i see a lot of you our running a 38r(not sure what mount style or size that is) or a h2e (once again not sure what style or size that is)
i also see on here where you just go get a 66 or larger t4(yes you would need a mount) and go that route
personally i had a 66 on my 6.4 and when it lit it would set you in the seat but cruising a highway speeds ect it was Smokey and laggy(most defiantly a tuning issue)
so is it possible to get a 450-500rwhp 7.3 that can tow 10,000 and keep your egts down and not have massive turbo lag?
let say you have supporting mods done and you put 250/200 and a ball bearing high quality 66 on it would that cut it? Or would you need to move more air then the 66 can supply
CSIPSD
Bend, OR
With a PMR motor, unless you are willing to deal with Window 7.3, leave it stock.
I've broke a lot of ****...
Never a PMR...
AC's are good, 425-450hp is good IMHO...
Yes...
230/100's-250/200's and a H2e is a 450-500hp set up that will tow all day.
