7.3 stuck on defroster
bordo380
I was hoping you would respond Ervin. Is there a chance the diaphragm in this thing is blown from running all the time?
Thanks for the info. I'll get under there and see.
Arisley
Arlington, Texas
Do I know you, how do you know my name is Ervin?
You can unplug the main line from the pump and see if you feel suction. That will tell you if the pump is actually working. Once you confirm it is working, just follow the lines until you find the leak. You can replace the lines for really cheap also.
bordo380
You name is in your profile. I live in Arlington too.
My name is Aaron.
You usually have plenty of helpful fixes on these trucks. I appreciate it.
bordo380
I work near the ballpark and live off green oaks and I20
Arisley
Arlington, Texas
I live near the ballpark. Right off Bowen road, north of Division. I used to live down off near Green Oaks and 20. I used to work at AppleJacks Liquor way back in the day.
01pwrstkr
Polk County NC
I just fixed my friends excursion that was doing this. It was the vacuum solenoid. Mounts on the fender by the vacuum pump and battery. Has a white rectangular cap with one electrical plug and two vacuum connections towards the bottom.
Sent from my SM-N920R4 using Tapatalk
bordo380
Mine is this canister. It's leaking I guess.
I just plugged the pump in directly to the AC line and it's the best air flow I have ever had. I guess I'll pull this thing and try to seal it.
psduser1
on the road
OR throw it away. None of my trucks have it, with no issues.
Manual lockouts, of course.
bordo380
I put OE hubs back on. I might try and get it all working right. It might be more work than I got time for now. I'm good to manual lock for now.
Arisley
Arlington, Texas
Yeah, that's a vacuum reservoir. Sometimes you can seal them with a hot knife, just plastic weld a crack back together. Pulling it out and throwing it away also works good.
bordo380
Has anyone ever replaced this part? It's pretty hard to find.
