dsberman94
Wholly crap. Usually the inevitable oil leak keeps everything pretty rust free. Is that "aluminum" bolt rusted or dirty or did someone put a steel bolt in instead?
hell even if you can get a mapp gas torch in there to heat it up that might help. PB blaster or Areokroil work wonders.. i would soak it every day two or 3 times a day for 3-4 days and go from there..
I wonder if the head of the bolt breaks off if there will be enough room to lift the turbo up and off...
That sounds like a super fun time LOLI sprayed mine every morning for a week and then drove it. The heat cycles really loosened it up and pulled the aerokroil in.
If he could get the heads snapped off you lift it enough to get a saw in there and cut more off the front bolt. Then rock it out. Had to do that once
