PsdPullerJr
Stealth twin HPOP with both pumps and twin IPR. Ran fine, ran with B-code injectors. I did have to use some sealer between the alum block and the front pump to keep it from leaking, which was listed in Stealths install intructions. Im not sure how many miles are on them. $800 shipped
Full Force 350/400 B-code injectors. Run great, have somewhere 5-10K miles. Will include new O-rings $2000 shipped
Wimer Fuel Injection 2.5 turbo. Has approx. 500 miles and 2 sled hooks. S400 based with their own cast, custom cover with v-band outlet. It is T4 based, and there is a little bit of a fitment issue on a 7.3. Wont work with aftermarket plenums unless the mount is raised .25-.5 inch. Ill give more installation details to a serious buyer. $1500 shipped
