OBS-Addiction97
Ended up trying some MTL. It made a noticeable improvement.
Glad the MTL is working for you should buy you some time, how about the miss?
j
It still has a very slight miss that’s intermittent when warm. I haven’t had a chance to pull out the IPR. When it’s cold it runs perfect.
Sounds like it might be in need of an IPR o-ring rebuild kit. I think Riff Raff stocks them. Usually when you have a great cold start and no hot start it’s usually IRP o rings that need replacing. So this could be start of concern.
j
So missing under load or at idle? And takes longer to start when at operating temp than cold? Make any difference when warm at idle if clutch is pushed in or left out, relating to engine miss. Would be handy if you had a code reader to check if it’s thrown any Diagnostic Trouble Codes. Just trying to get clearer understanding of symptoms....
j
