97 7.3 injector issues?
franklee95
brooklyn ohio
I have a 97 f250 with 160/0% injectors with apparently less than 90,000 on them and the issue is when I start the truck 1 it takes some time to start then once it does it is missing, now the miss wont go away till the truck warms up and I get on it. but it still has hesitation if I were to put it to the floor from a dead stop. now so far I have a new hpop (adrenaline) new icp, used but good ipr, new cps, and ive changed the oil and filter along with checked fuel pressure. now when I add atf or fuel additive it helps it open up earlier. ive ran both buzz (passed) and contribution tests multiple times and usually they change over time. any ideas suggestions? please help im low on money and this is my daily driver while I work and im a full time tech student
POWER-STRUCK
Indiana
often a bad injector will pass the buzz test with AE. do you notice any differences in sound from injector to injector during the buzz test? (cold)
franklee95
brooklyn ohio
yeah I was gonna have rosewood do em because they are only 50 min from me right now oh also the truck sometimes lopes for a few seconds on start up also injector issue?
