97 obs Cummins swap
woodduck97
Maryland
Whats everyone doing for the shifter for the tranfer case? I got a 48re with a super duty manual transfer case. Any input would be appriciated.
suprhlr
Zeeland MI
this is in my superduty, but maybe it will give you some ideas. 48RE to a 271F
ghohouston
Lewisville,Texas
Why not go with a built e40d? Seems it would be easier since you wouldn't need to add/adapt your harness. Or do you not want to pay the high cost of an adaptor plate?
Ncovey
I don't know if it helps or not since I used a nv4500/241hd combo, but I used a 2nd gen shifter that mounts to the floorpan. Didn't have to worry about mounting it to the transmission that way.
woodduck97
Maryland
Is that a factory dodge bracket?
I had a BTS in the truck. With the power I plan to make I didnt want to put that money in it with the new billet flex plate and adapter plate.
TurboM700
Minnesota
Do you think a built 48re is going to be cheaper?
Your still going to need a controller to control the 48re. If you already have the BTS I would really look at an adapter and flexplate.
woodduck97
Maryland
Yeah it was cheaper actually. Sold the bts for 3500 bought a 48re built buy darren morrison with everything that can be put in it quad disk converter billet flywheel and a tci shifter box for 5k.
BDS
Telford, Pa
I just threw out the modified linkage I made to adapt to a 48RE !!! It ashame, But I cut the OEM linkage and re-clocked it then welded it back together. shortened the linkage arm and it worked perfect. I mounted the works to a 1/8" steel plate and bolted that to the tabs on the 48RE
