high desert stroke
Quiet buzz test leads me to idm... A buzz test is LOUD
crap...how can I test it?
Have you checked the wires at the ipr? It could have a bad connection there or a bare spot in the wire. That could cause it to cut out like that.
Thats good. Is the small nut on the ipr tight?
Im talking about the nut on left in picture. On my truck I had a issue where mine cut out, that was my issue. I had to tighten the nut up. Just something to check.
Be careful when you tighten that nut. It is a sheet metal nut and easy to strip out.
Ok, today I cleaned the tube and replaced the EBP sensor. It was plugged. I swapped out IDM's and getting it rescanned today at 4pm. Going to do the buzz test again and this time ill film it. Hopefully its better. While swapping the IDM I found this connector and have no idea where it goes...any body know?
[/URL] Uploaded with ImageShack.us[/IMG]![]()
