A/C question
Poon
my door is not run by a cable, its vac, that is the actuator under the hood on passenger side on top of the fan box.
I know when I watched mine you can see the actuator move as you turn the knob in the cab to max ac
46 is really good, maybe you saw 40 because there is no load on the motor, its just sitting on high idle, don't know.
Yes my fresh air door is also a vacuum operated but the cold/hot door is cable operated.
