windrunner408
- Joined
- Jul 27, 2011
- Messages
- 1,496
- Reaction score
- 0
Actually what should the line pressure be at??
Ok. After thinking.
I am guessing because i cant drive to feel it, so to be safe, have you ever had any tranny work done? Filters replaced, fluid, anything at all. Wonder if it is grinding itself causing this. Has your truck been in the extremes? (temps Truck and ambient.) This is my first course of action as I don't like buying tranny parts. Recommend changing filters blowing out lines change fluid. Fully service and flush the transmission. Its bout that time anyway. To me its an important thing to do to keep everything running top notch and keep my mind at ease.
If it is not that drink a beer.
How to tell if its the vgt solenoid. Just a guess. When the problem series of events occur, pay attention to the sequence of events. If the turbo changes THEN the engine is affected, the solenoid or turbo could be at fault. If the engine affects the turbo then rule that out.
Get that much figured out.
I'm no expert but here are my initial thoughts/questions..
All this is assuming the trans is OK.
1. Like Sixohh first eluded to, what is the VGT solenoid doing? Perhaps it's spazzing out sending the truck into an overboost situation causing the PCM to limp. With boost only raising a few psi, I have doubt about this being the culprit.
2. What is your ICP doing when it acts up? Perhaps an intermittent fault here or with the IPR?
3. What is FICM voltage doing when it acts up?
4. What is your EOT/ECT delta when this problem pops up. The PCM may be seeing too big of a difference and going limp.
Does the truck recover on it's own? Does it require a shut down and restart to straighten out?
One last note/question, I've been under the impression for some time that the EBV was disabled some time ago in newer strategies???? I'm I all wet?
I may be barking up the wrong tree here, but it would be interesting to see what commanded and actual ICP is when it acts up. Even if the ICP sensor itself isn't the issue, that would give you an idea if the PCM was limping. If the PCM pulls ICP all of a sudden it may point to some other sort of electrical fault.I havent monitored ICP and I wouldnt know if it would help until I go drive the truck with the stock tune on it as if it is tuned the ICP wont be accurate anyways. Nevertheless I could watch for the change in ICP.
With the CTS I'm not sure you can look at commanded. Sorry, I was under the impression you were using AE.How do i see what commanded ICP is? I can see what actual is but dont think the CTS does the commanded option. However, I did note ICP voltage was 1.7v while cruising and .8v at idle. Not sure if that helps.
The voltages sound right though IIRC, so yeah that does help. Have you gotten a voltage from the ICP when it acts up? That may not be all that relevant not knowing what commanded ICP is, but would be handy info for elimination purposes.
Have you happened to look and see if you're getting a CKP and CPS signal while it's acting up? Without a CKP signal, IPR duty cycle will default to 14% or 300 psi. I'm wondering if the CKP signal is crapping out once the sensor gets warm. My other thought is that the two signals may be unsyncing, although I don't personally know what happens in that case while you're cruising down the road. I DO know that will cause a hard/no start.
I apologize if I seem all over the place on this. I'm hoping the process of elimination will help here though as the problem doesn't seem to be anything obvious.
Are you able to monitor all three air temp sensors? It sounds like your monitoring the OAT (ambient air located at front of engine compartment) and IAT (located in the MAF).
Can you pull input for the other air temp sensor on the intake? It might be called either MAT or IAT2. I've seen it referred to as either but my diagram calls it MAT.
My thought here is that the truck is maybe limping for not seeing a temp differential between the two or perhaps the value is totally fubared as far as the PCM is concerned. It's a long shot and I'm sort of thinking out loud here......
edit: Your ICP voltage tells me it's not pulling fuel. Anyone more knowledgable than me on the subject please don't hesitate to correct.
edit#2: Without further investigation into the CKP, this possibility can't be eliminated yet. I can see the CKP causing all your issues including being able to start out of the blue.
Sounds like the egr is taking a dump lol
Got ya. I am about 99% confident that it is a sensor that is affected by the heat or when the heat gets high enough the sensor reaches some sort of max range and then the ECM cuts fuel to protect the engine or the VGT solenoid is messed up when the heat gets that high.
Not sure on the fix for the problem, but havent we all decided that even with the egr delete that the valve still needs to be plugged in and layed on top of the intake to let the fan circuit read rite? Im not saying this will fix anything but I think it runs in a loop with the fan.
Considering this info, it doesn't sound like an overheating issue.EOT/ECT delta is about 10-18*F always. I have an oil cooler delete and my oil temp at the sensor fluctuates between 200-208F and ECT is about 190F all the time.
